frees-tyler
Just wondering which tracks you guys have tried on the Attak. I'd like to know which lug pattern and what the max lug height you can use. I'm assuming Camoplast has a pattern that accounts for the tunnel protectors...currently would like to put in a 1.75" if possible.
Cap'tAttack
I was just looking at that very same question today. I'm pretty sure that you can go to a 1.5 inch lug track witout changing drivers. Even at that you will have to remove the tunnel protectors. .Any larger lug and you'll have to change the drivers to an 8 tooth driver.
I know this is true for the Vectors and Rages.
Bodacious
I have a 1.5" using 9t drivers. I did however take out the protectors as studs are no longer an option with the 1.5" or taller lug tracks.
Yes I agree A 1.5 lug track is probably the biggest with 9 tooth drivers,
If you have the track out, you should change the drivers to a non ratchet type.
I am, I can't stand that ratchet noise, my track is so tight I can play a tune on it.
suprfst
- Dec 4, 2004
- Tawas Michigan
- www.smcfabrication.com
I had a 2" track on mine with the stock 9 tooth drivers pictures
http://www.ty4stroke.com/viewtopic.php? ... ight=track
mrtwostroke
- Apr 24, 2003
- Sweden,Lulea
- Sweden
- Sidewinder MTX 240 Tune Sidewinder XTX 240 Tune MountainMax SL 153.
I´m using 1,75 track with 9t drivers, you got to remove protektors.
SharkAttak
i've had no problems with the 1.25 ripsaw, but next year going w/ 1"
Alatalo
- Jan 11, 2005
Max lug height discussion:
Bodacious
I did install a set of 9T Wahl Bro's No-Slip drivers, can run the tack much, much looser now. Absolutly no ratcheting...period!
