Daonlyone74
- Jan 10, 2026
- Wisconsin
- 2010 Yamaha Vector ltx Gt
Not sure if its been discussed but couldnt find anything yet.
Does anyone know what the max lug height can be on a stock 2010 vector ltx gt? I know stock is 1.25". Will a 1.5 or 1.6" fit without modification?
If they cant fit what would need to be done to fit one? Im a newbie to these never sleds and modifying them.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
1.5
Daonlyone74
- Jan 10, 2026
- Wisconsin
Someone local to me has a used camoplast 0602-904 in good shap which comes in at a 1.6 lug. Would that clear is that pushing it?
pdiddy
- Oct 12, 2004
- Southern Maine
- '18 Vector 129", '18 Indy 600 SP
Keep in mind, even the 1.25 with studs will contact the rear heat exchanger without additional tunnel protection.
Daonlyone74
- Jan 10, 2026
- Wisconsin
I have tunnel protection. Is there any modifications that can be done to properly fit larger lug tracks or is this sled stuck to keep a 1.25"Keep in mind, even the 1.25 with studs will contact the rear heat exchanger without additional tunnel protection.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Unless you remove the tunnel protectors 1.5” is as tall as you can squeeze in there. Forget studs with a 1.5” track as well, you’ll have mega contact trying to run them and cause tons of damage unless you swap out to 8 tooth drivers and space the skid down out of the tunnel.
1.5" will have clearance. 1.6" will be really close. just spent 2 hrs looking at the tunnel protectors on the cooler by the drivers on my 11 with the 1.5" track.
Daonlyone74
- Jan 10, 2026
- Wisconsin
Do you still have the protectors on with the 1.5" ?1.5" will have clearance. 1.6" will be really close. just spent 2 hrs looking at the tunnel protectors on the cooler by the drivers on my 11 with the 1.5" track.
yes i do.
darv
- Aug 9, 2005
- 08 Apex 40th LTX
it is the front you need to worry about if you put a 1,5 no studs
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
The track runs pretty close to the protectors everywhere with a 1.5”, just hung one on a ‘14 Vec. with the protectors left in.
