APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
Guys I was going to replace my Coolent (100%) to (50/50). I pulled the cap off the radiator and there was oil looking spots. Sled runs fine, oil looks fine-no milkly color. Thinking if its oil can I replace the head gasket with the motor in the sled.
Help
Help
Do a pressure test it may be nothing more than someone added coolant with a oily funnel.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
same pressure test as a car right
09nytro
Yes
APEX 06
- Apr 30, 2009
- Sheboygan, WI
what pressure should the nytro be tested at.
Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '21 SRX, '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F,
it doesn't take much pressure to find a leak so if you keep it 10 psi or under you should be fine. Most coolant system caps "pop-off" at around 16-17 psi.
