T-rav 27
- Apr 16, 2017
- Sudbury
- Srx 700 imp,1100 turbo, mcx apex
Hey guys im installing mcxpress turbo on my 2008 apex i cant seem to locate were the red and black wire tie into for the extra fuel pump included in kit there saying to cut the stock wired and use that can someone poat pics or have any other info thanx guys
spddmon
what i used was the harness that goes from the grey connector on the main harness to the stock fuel pump removed the connector at the pump end identified the positive wire used the supplied hoop connectors installed the proper wire on the proper connector on the pump, there should be an aluminum adapter to replace the stock fuel pump in the tank
brapcounty
- Aug 14, 2017
- Washington State
- 2006 Apex Mountain
MCXpress turbo
red wire feeds off of the fuel pump power wire. black wire goes to chassis ground.
