rx1turbo
- Jan 6, 2007
- Burns Lake British Colombia Canada
05 rx-1 mc rear mount. Have pistons and head shim just wondering what boost i can run on pump fuel approx 3000 feet elv with meth injection Thanks
yamiboost
- Feb 17, 2008
- Labrador,
- 15 SR Viper MTX Hurricane 300hp kit
Fx Nytro Drag Sled 25psi + Boss Nos
If your meth is setup right you should be able to run whatever boost that turbo can make even on 87. If your gonna run over 10psi on pump i think you should have arp studs tho if you don't already. Hurricane has made over 400hp on 87 with meth.
Skydog
I ran 15PSI+ all good!!!
Skydog
Skydog
rx1turbo
- Jan 6, 2007
I have just the stock studs so 15 to16 shouldn't be a problem then. I was running 24 pounds drag racing but race fuel is a little pricy
Blue shadow
running c-12 and meth on 21 psi ,I would not chance it at that high on just the meth alone with the stock rods
