RIKMAN
Anyone having to refill coolant tank after each ride. Got 1200 miles on new SRX. The last 3 rides, i had to refill the tank after each ride. No leaks visible and went through all clamps. I’m assuming air was trapped in tunnel cooler from factory.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Probably trapped air. Take the hood off. With the sled on flat ground, stand on right running board, grab bars and roll sled to the right. Once it comes up, push down on the running board and slowly lean it as far as you can without putting it on the ground and slowly set it back up. You will hear the gurgling in the back of the sled if there is air. Check the fluid level under the pressure cap, top it off, repeat till it doesn't drop any more in the system after leaning it over. Had to do this about 10 times before I got it all out. I had to drain it completly because I had to fix a hole in the front heat exchanger from a thrown stud. The way the coolant lines run, when you lean it to the right, the thermostat housing where the pressure cap is, becomes the high spot and air can run to it.
kuvasz
check the oil, that's where the antifreeze is probably going. head gasket or cracked block.
RIKMAN
Thanks, will give it a try.
Oil looks good, runs fine and no white smoke comming from exhaust.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Mine also need coolant the first thousand miles or so. It has since stopped needing any coolant added. I think they just have air in them and need topped off when new. If it doesn't stop needing coolant shortly, then I'd start looking for other issues.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
2 things to check....
Air lock, not properly bled at factory....
Or
A worse scenario, that has been seen a couple times. This will show up in oil tank as mentioned above. If your oil tank is way high that is the worse case scenario, better hope the engine is not tuned if you want warranty.
Dan
Or
Dan
RIKMAN
Thanks Knapp..
I'll keep a close eye on it. Hope its that simple..
Or
Dan
Dan, oil level is ok and no coolant mixed with oil. Running TD SM Jukebox.(MS16 most of the time). The sled works great, never did overheat.
1CoolZ71
We just did this dance with a friends Sidewinder.
After putting a florescent die in the antifreeze, he found that the HEADS HAVE POROSITY!!
They leak when hot and under pressure. The coolant goes into the cylinders and wreaks havoc on the pistons.
Even though the motor passed coolant pressure testing, it will still leak when hot and running down the trail.
You won't find coolant in the oil because it is leaking into the cylinders.
Yamaha gave him a brand new motor under warranty and over-nighted the old motor back to the factory!
RIKMAN
Sure hope it’s only trapped air..
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Mine did the same when new. Check all your coolant hose clamps. 90% of mine were loose.
MUSKOKA SIDEWINDER LTX LE
Your oil level will tell the tale lets hope its not up there ughhhh
1CoolZ71
Sorry but the head leaks into the cylinder, so it goes out the exhaust rather than into the oilYour oil level will tell the tale lets hope its not up there ughhhh
We have a couple of reports that when antifreeze is missing it's ending up in the oil reservoir.
Pstn head
Check all your hose clamps for tightness and seeping coolant. Even remove the charge tube's/intake tube's, tube from air filter to turbo and check every single hose clamp which carries coolant under that one. I sure you'll find a couple loose ones under there. It's a bit of a job, yes, but almost guaranteed a few are loose.
1CoolZ71
That may be true, and very possible but the OP already said his oil level is good and no signs of water.We have a couple of reports that when antifreeze is missing it's ending up in the oil reservoir.
I'm just giving an alternative that we actually had happen.
Yamaha was so worried about the leaky casting that they over nighted the motor to Japan. BIG $$$$$$
- 32K
- 122K
