we have a 2007 RS rage gt with the mono skid. does anyone know which spring is the stock spring for thiat sled? I notice there are 6 different springs and rates available for that skid reguardless of the model it was put in. Ihave heard there is a difference in the stock spring rate between the 121" and the 136". Who can help me out here.
Stock your 136" Kayaba Monoshock skid in that Rage would have had the 5.0kg spring - the 121" Kayaba Monoshocks have the 4.5kg spring. If you are going to go to a stiffer spring take a look at the 6.5 or 7.0kg springs (fyi-the 7.0kg spring is the most common used on the 136" and the 6.5kg spring is most commonly used on 121"s).
