turbine man
is there way to put more pressure on the front of the skid, theres only the one spring to adjust. Does that help the front also, i have the limit strap fully extended. Steers hard with 75lbs in the front shocks when i take them dowm to 50 lbs sled sits to low in the front , but steers a little easier. didnt have this problem until i changed the sup. this summer from a proaction to a elt. monoshock. Skis are shimed, hate driving it like that seems like its allways nosediving, a arms are level at 50 lbs. 07 rtx / elt.
markshop
Extend limiter dtrap
turbine man
THANKS THE STRAP IS FULLY EXT ALLREADY FORGOT TOOK OUT ALL PLASTIC BUSHINGS AND REGREASED THEM ON THE STEERING SHAFT ALLSO.
CrankyApeX
- Oct 5, 2007
- Woodbury, MN
- www.crankyape.com
I did the same thing with my 07 only I have the dial adjust Mono..I pulled the front strap up 2 holes and have the floats at 50 PSI..steers very easy and corners very nice..How did you measure the holes for the Mono?turbine man said:THANKS THE STRAP IS FULLY EXT ALLREADY FORGOT TOOK OUT ALL PLASTIC BUSHINGS AND REGREASED THEM ON THE STEERING SHAFT ALLSO.
