13XTX
- Jan 2, 2017
- Nova Scotia
- 2013 Yamaha Nytro XTX 1.75
Heres my Garmin Montana 650T Mounted to my 2013 Yamaha Nytro X-TX 1.75 using Ram Mounts and Garmin charger/mount combo, i removed the little yamaha cover in the middle of the handle bars and mounted it to the bolts that hold the handle bars in place. Only issue i had was the aluminum blocks that hold the handle bars have a small grown on them and i just ground them flush it ended up cracking the 6.25" x 2" plate when i tried tightening it up ordered another and fixed the issue since. I wired it into one of the accessory plugs so i have it on keyed power but you could also mount it directly to the battery using a fuse! I ordered the chips(maps) from TrackMaps and they work awesome, trails are well marked and shows places for fuel, lodging, and restaurants!
-Garmin Marine Mount with Power Cable - PART NUMBER: 010-11654-06 (Garmin Website)
-Ram makes a 1" ball mount that will bolt right to the Marine mount and charger its 2"x1.7"- RAM-B-347U
-Ram Short Double Socket Arm size 1" ball- RAP-B-201U-A
-Ram 6.25"x 2" (cut to size and drilled appreciate holes)- RAM-111BU
