Mills
- Dec 4, 2007
- Elk Mound, Wisconsin
- '14 Viper RTX, '06 Apex, '99 SX 600, '74 TL433F, '79 Trail Fire
I know people have swapped the Apex 4cyl fuel injected motors into their Vipers and called them a Vipex but has anyone swapped an SRX or Sidewinder turbo motor into an Apex to make the sled lighter with more power?
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
Lighter? Nope.
More power? Okay.
Why not just turbo a Vec and have the same ish thing?
More power? Okay.
Mills
- Dec 4, 2007
Because I am tired of the purely A.C. parts on my Viper failing like bearings, top gears, shift fork guides, cross-over tube in rear suspension....Lighter? Nope.
More power? Okay.
I also thought the challenge of swapping the motors would be something I would like to tackle. Just wanted to know if anyone has done it and what issues they ran into. Summer is coming so it is time to put the sleds away and get the UTV/camper/boat out
Stubbs
- Nov 7, 2006
+ other gooodies
- Uxbridge ON
Listen, I get it…….I’ve been reluctant to join the Yamacat party for all of the reasons you’ve just mentioned, but instead of shoehorning a ‘Winder motor into a DBII chassis, why not simply buy a Vec and turbo it? You’re gonna end up with the same ish sled, that’s all I was trying to say.
I rode a winder several times over the last couple of days, and as a result, I’m on the hunt looking for another Apex.
Mills
- Dec 4, 2007
You are probably right. Based on the time i have available these days with work, kids, home projects and teaching safety classes for the DNR I don't have much left over to take on this project now.
20/80
Hmm, I thought and was told many times from members on this site that the pro cross was the most trouble free best chassis they have ever own and a OEM have ever built, I was under the impression that Doo, Pol, and old 2018 Delta box 2 chassis are nothing but pure junk and unreliable and would cost you thousands to keep them running on the snow, I will note though that I do own a delta box 2 chassis and has been very trouble free and very well built, Yes... camping/ Atving /fishing/ boating are on the horizon.
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
Well all I can say is that the 100% Yamaha built sleds I own (2010 Phazers) have probably been the worst built sleds I've ever had in recent years. The engines are fantastic but the chassis leaves a LOT to be desired. After 5k miles, nearly every moving part is completely worn out or loose. The old Cat's I've owned from the 90's - 2000's (still own a few) held up substantially better in this department. I did however know all about these chassis deficiency issues with the Phazers before ever purchasing them and have no regrets. After many updates/improvements I now have two well sorted Yamaha's in my lineup. The same can be said for the Procross chassis. If one does all the know, well documented updates they too can be a rather wonderful sled to own. None of these machines are perfect, just pick your battles wisely and enjoy the ride!
farmerz24
- Nov 3, 2006
I’ve started this swap on a sidewinder. It’s almost a bolt in. I attached it to the rear stock engine mount and had to make a new tab on the front. Also had to notch some of the chaincase and the side aluminum stays
Mills
- Dec 4, 2007
Are you swapping an Apex motor into a Sidewinder or vice-versa?I’ve started this swap on a sidewinder. It’s almost a bolt in. I attached it to the rear stock engine mount and had to make a new tab on the front. Also had to notch some of the chaincase and the side aluminum stays
farmerz24
- Nov 3, 2006
apex into winder.Are you swapping an Apex motor into a Sidewinder or vice-versa?
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
Cool I wanna know how that turns out!
You can follow the motor swap here
BoostedApexWinder
MY build of a Apex 4cyl into a sidewinder.: Will probably run the gen2 gt2876 turbo. Chaincase mount notches Clutch alignment once bolted to the back factory mount (only need to cut off the outside tab on the rear mount closest to chaincase, use a shortened apex rear bolt as the...
ty4stroke.com
