How exactly do you mod the drop brackets to work with the '05 vector?
p0wd3rp1l0t
i would like to know how drop brackets work...or wat there suppose to do?
It is what your upper rear track suspension is mounted to the tunnel with. Instead of the heavy steel yamaha bracket you replace it with a alum. one.
p0wd3rp1l0t
yeah i know what it is just dont knwo what teh point of droppin the bracket...i have seen ones made out of billet alum with many holes drilled in them...i didnt know if it was for weight savings or for adjustability for different conditions
Dr Nitro
drop brackets are to give you more traction in deep snow aka{more clerance before you bottom out the tunnel and running boards in the powda.
