upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
Finally found an intercooler for my 15 Viper XTX and plan is headshim and Studs next year but want to install intercooler and quick spool waste gate this year…Question I have is the intercooler comes with the high flow billet blowoff valve, and my understanding is there is a already a blowoff valve on the mpi turbo set up…Do I need to block anything off?
Set up…Dealer installed MPI turbo, 2.5 inch DD can, PC 5 pti, pod 300, autotune, hurricane map, 6 lbs of boost at sea level.
Thanks in advance
Thanks in advance
Thanks in advance
Do you have any pictures?
upei93
- Apr 27, 2008
- Dalhousie, NB
upei93
- Apr 27, 2008
- Dalhousie, NB
You currently have a Turbo with the other style non cooled air box for the turbo?
upei93
- Apr 27, 2008
- Dalhousie, NB
Yes the Yamaha MPI low altitude kit that was a dealer add on with the above mentioned changes. I also have the bigger injectors.
All the hookups should be the same and really nothing will need to be capped from what I can remember when I have converted them.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
You will use both the BOV on the turbo and the intercooler, simply tee into the vacuum line currently going to the turbo BOV and run a line to the intercooler BOV as well.
upei93
- Apr 27, 2008
- Dalhousie, NB
I have never seen them run both, thanks for the input.
upei93
- Apr 27, 2008
- Dalhousie, NB
Thank you both for the help!!
upei93
- Apr 27, 2008
- Dalhousie, NB
Finally getting around to doing this...there is a blowoff valve on intercooler...should I cap the one on turbo and run line to one on intercooler?All the hookups should be the same and really nothing will need to be capped from what I can remember when I have converted them.
I would cap one or the other. You only need the one blow off.
- Apr 17, 2003
- Menno, SD
- Menno, SD
You can cap the turbo one, but it also won't hurt anything to run both either. The one on the turbo will not make any external noise, the one on the intercooler you may hear slightly!
upei93
- Apr 27, 2008
- Dalhousie, NB
Thanks!
- 8K
