justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
- moncton new-brunswick
1. I can get my hands on anxmpu super charger kit for my 06 apex. Complete kit for 1000$ cad. The only thing I need to install it myself. I do mechanic for living so think I can figure it out. Was looking on the mpi wen page at the instructions... Just wondering if anyone has better instructions on how to install these.
2. How reliable are they? If I go go get than stage one do I need a head shim and bots? If I do can I still run pump gas or will I be mixing with race fuel?
I'm be to boost so any help would be great. To be honest I'm not even sure what stage this kit is... But I'm sure it worth more than 1000$
I had a friend with this kit on same year Apex, he was running 7lbs at sea level on premium fuel, stock engine, which I thought seemed like a bit too much, but it stayed together. I can't remember the pulleys used to get this level of boost, but a call to MPI will answer that.1. I can get my hands on anxmpu super charger kit for my 06 apex. Complete kit for 1000$ cad. The only thing I need to install it myself. I do mechanic for living so think I can figure it out. Was looking on the mpi wen page at the instructions... Just wondering if anyone has better instructions on how to install these.
I did install one of these kits on my Nytro i used to own. It took myself and a friend about 7 hours, but it was the first one we had done.
BTW, the Apex was very fast with this kit, you won't be disappointed. Can's say the same for the Nytro kit, it was faster, but not by a huge amount.
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
than joy....was this a stage 1?I had a friend with this kit on same year Apex, he was running 7lbs at sea level on premium fuel, stock engine, which I thought seemed like a bit too much, but it stayed together. I can't remember the pulleys used to get this level of boost, but a call to MPI will answer that.
justin gallant
- Aug 28, 2017
- moncton
- 2006 apex GT
In order to set the boost on theses is if done by re0lacing pulleys? And does that change the stage or stage 1,2,And 3 are tottaly different kits all together!?
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
Yes boost is changed by changing pulleys. Stage 1 compressor is different than stage 2&3.
I can't recall pulley settings for stage 1, but the setting my friend ran at was higher than the stage 1than joy....was this a stage 1?
Do you have a boost guage?
Riceburner
- Apr 14, 2003
- N.B. Canada eh
- SideWinder LTX 50th
22/26 for 5/6 psi early pulleys. 23/ 27 for later ones.
Reverse them for 10 to 12 psi.
No head shim or low compression pistons needed for 5-6 psi.
Make sure blower shaft is not broken before you buy.
Not a tough install.
