You might want to tell everyone what you need a map for. IE: Apex or Nytro and what fuel controller you are using. Also, what size are your "big injectors".Sibola said:Hello I've got a s/c mpi stage 2 with big injectors, running around 11psi. Looking for a map around the 5000 foot mark. Leaving on a ride shortly don't have time to make a map in our mountians. Also it has a head shim with stock motor, running 91 octane, and stock fuel regulator, with msd fuel pump.![]()
TurboMatt said:You might want to tell everyone what you need a map for. IE: Apex or Nytro and what fuel controller you are using. Also, what size are your "big injectors".Sibola said:Hello I've got a s/c mpi stage 2 with big injectors, running around 11psi. Looking for a map around the 5000 foot mark. Leaving on a ride shortly don't have time to make a map in our mountians. Also it has a head shim with stock motor, running 91 octane, and stock fuel regulator, with msd fuel pump.![]()
I won't be able to help you with a map, but I know anyone that is going to be able to help you is going to need this info.
