wr420
- Jan 19, 2010
- quakertown pa
- 17 Sidewinder RTX
14 Viper RTX
08 Yamaha Nytro Supercharged stretched to 136"
1980 Yamaha Enticer
- Quakertown PA
Can someone tell me the procedure for changing the oil in my MPI supercharger? I have the traction oil and filter from MPI but not sure what the process is. Any help would be appreciated.
ShafeNytro
- Nov 13, 2012
- Wooster Ohio
- 2010 Yamaha Nytro XTX
- Wooster
https://www.google.com/url?sa=t&sou...E90kpxSLVhl1_ctLQ&sig2=5Hzc_oy7GngkLSR4g6ftnA
Good read but I have not changed my oil yet. Not sure on mpi procedures.
ShafeNytro
- Nov 13, 2012
- Wooster Ohio
- Wooster
That is Rotrex technical book for the c series superchargers.
wr420
- Jan 19, 2010
- quakertown pa
- 17 Sidewinder RTX
14 Viper RTX
1980 Yamaha Enticer
- Quakertown PA
Thank you. That told me everything I needed to know.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
intresting that there is a priming procedure as MPI told me it was self priming and anyoil was good oil at the return????
ShafeNytro
- Nov 13, 2012
- Wooster Ohio
- Wooster
What do you mean, that any oil was good oil at the return?
Support@MPI
TY Advertiser
- Feb 24, 2015
- Yamaha
Any oil is good oil? Not sure what your trying to say.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
When I called about if my oil coming thru my return line was enough volume at idle or should I prime the unit to see if it increases the guy who answered the phone went and asked someone else and when he returned he said the pump is self priming and any amount of oil returning was "good oil" the directions posted from the manufacturer says you need to prime it and states how to.
Sent from my SCH-I545L using Tapatalk
Support@MPI
TY Advertiser
- Feb 24, 2015
- Yamaha
Is your Super Charger returning traction fluid or not?
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
It seems to be just at a trickle thou
Support@MPI
TY Advertiser
- Feb 24, 2015
- Yamaha
Perfect. Its not going to be a garden hose at Idle.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
Thanks I appreciate your help
PowderFalcon
Pinnin' it!
scuba_nytro
- Feb 1, 2011
- 2009 Nytro RTX MPI Stage 1, Hindle Exhaust, Evolution Re-flashed ECU, Ulmer Clutch Kit, Split Rail Skis, etc.
The oil reservoir/cooler on my Nytro is 1/8" NPT I would assume it is the same on the Apex.
PowderFalcon
Pinnin' it!
Thank you!
