MTX 162" more cooling
kimoajaj
Norway
Hi !
Has anyone added more coolers / cooling system to an MTX ?
This weekend I got the rews limited due to overheating, happened when I stopped the sled and let it idle a little while whilst deciding what line to pick. Snow was hard packed just before I stopped and I didn't have the ice scratchers out.
I`d like to not mess around with the scratchers all the time, plan to keep the sled for many many years like I did with my Nytro and therefor I wonder if I should upgrade the cooling system since I will be riding in various conditions.
Any opinions?
You can install a Long coller from btx, or xf9000. Mm racing makes radiator with fan for sidewinder/9000.
Aha ok thanks for the reply!
Tried googling MM racing but didn`t find anything.
Will a cooler from a BTW bolt straight on ? I figure there will be some different pipes or hoses?
I believe Barn of Parts Travis has a Rad and Fan also.
CR Racing has larger you cooler replaces one it has. Also you can change ur boards or add after market coolant lines thru the OEM boards. I know Lincoln County Customs does the cooling system mods as well and prolly sell everything, but you'd have to call them for details.
