2010 MTX and XTX arm numbers are the same except for a "P1" and "P0" at the end of the part number. I believe to only difference would be the 2010 MTX ski stance is 40", compared to the XTX 41" ski stance. With both sleds having the new and improved geometry.
XTX got the improved geometry in 09, while MTX got it in 2010.
Makes sense that the ball joints numbers would change as they are updated. It is common in the automotive field the change part numbers when the part is updated. Often the new part number will fit the older applications.
Not sure if this info helps ya, but I thought that I would put it out there.
