iam_canadian22
Is it possible to convert the steering on an xtx to the mtx style? I wish they made the btx in a 141 as its the perfect ballance for my area but thats not the case. So im wondeeing if i can make one myself from an xtx?
Pstn head
Shouldn't be a problem, I was looking at my buddies on his Cat. It's just a bracket, linkage, and support with some fasteners.his is factory and the regular support is still there left in place but empty.
iam_canadian22
Thanks, any other major differences aside from the narrower front end on the mtx?
Sent from my SM-G930W8 using Tapatalk
vector boy
- Nov 5, 2014
- Norfolk, NE
- 2018 Sidewinder MTX LE 153
All Sidewinders use the same post (XTX style). If you're wanting the MTX style off the Viper the parts list needed is as follows:
8KG-F3813-00-00 (COLUMN,STEERING 2)
8KR-RA816-00-00(BUSH, 7)
8KR-F1957-00-00(BRACKET, STEERING)
8KR-F1947-00-00(BRACKET, STEERING)
8JP-RA379-00-00(NUT, LOCK 1) qty 2
8JP-RA1B4-10-00(FLANGE BOLT)
For 2017, there weren't major differences between the XTX and MTX other than the narrow front end. For 2018, the MTX has a dropped and rolled chaincase where the BTX and XTX do not.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
In 17 the sw xtx le was a 2.25 141, basically a 141 btx.Is it possible to convert the steering on an xtx to the mtx style? I wish they made the btx in a 141 as its the perfect ballance for my area but thats not the case. So im wondeeing if i can make one myself from an xtx?
iam_canadian22
Thanks, thats what id ideally like but with the narrower front end but that shouldnt be too difficultIn 17 the sw xtx le was a 2.25 141, basically a 141 btx.
iam_canadian22
Thanks, i thought they used different posts like the vipers did, good to know. The chaincase i assume is just to clear the taller lug?All Sidewinders use the same post (XTX style). If you're wanting the MTX style off the Viper the parts list needed is as follows:
vector boy
- Nov 5, 2014
- Norfolk, NE
The dropped and rolled is to accommodate taller lugs with an 8t driver, shallower approach angle to get up on top of snow better, and also helps changing the center of gravity a smidge while riding.
