Mud Lite XTR RADIAL tire with 14-INCH C-Series RIM
I just put on a set last Wednesday. So far so good, they are heavier though and you can feel that difference. I had my Grizz up to 45 mph with them and my handlebars started to sway back and forth a bit. I have not put the mileage on them required to really do a better analysis, but so far I like the stability, you hit bumps, I took them over a spot where black top meets grass and you don't even feel the wall of the black top (about 4-5 inches tall).
They don't quite steer as nimble, if you will, as the stock Dunlop's. I wonder how they compare on hard surfaces to the Mud Lite XL's? Only drawback I see is the weight. I'm already 215 pounds as it is. I read a test review on this wheel kit and they (Dirt Wheels) used a Grizz 660, you can view this same review at ITP's web site, and they mentioned that they had no trouble getting it up to 60 mph. However, most of the guys that test ride are built like horse jockeys.
Nightwing
- I'll give more feedback later as I use them more.
I HAVE THEM ON MY 660. REALLY LIKE THEM , DONT THINK THEY CORNER AS WELL AS THE NORMAL MUD LITES AND ARE PRETTY HEAVY. BUT I HAVE TAKEN ON SOME NASTY NASTY BUD AND WATER WITH THEM AND WORK GREAT . TOP OUT OK IM 200 LBS AND CAN GET TO 60 PRETTY EASY. ONLY DOWN FALL IS ONCE U DO SPIN THE TIRES AND DONT MOVE U CAN DIG HUG HOLES REALLY FAST BUT THATS EXPECTED. I HAVE THE OTHER MUD LITES ON THE WOLVERINE.
