Blown14psi
Does anyone know what happens when the engine, on an apex, hits the rev limiter? Does it cut fuel, spark, or both? I'm curious because I'm using a wet N2O kit and if it cuts just spark or both fuel and spark that should be no problem. If it cuts fuel and not spark then we have a big problem LEAN OUT and possible engine burn down if the engine bumps the limiter for an extended period of time.
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
I always believed it was spark that was cut out by a rev limiter.. Anyone ??
- Apr 14, 2003
- Hessel, Michigan
Cuts the spark, and will give you a slight pop sound on the bottle. Hit this many times and still no problems, but you don't want this to hit all the time. I usually hit the rev limiter when I have loose snow conditions.
at what rpm does it cut out and is it the same on an rx?
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
jminor1 said:at what rpm does it cut out and is it the same on an rx?
There is a number(11200?), but it seems people have revved the motor higher on the tach.....
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
11,200 rpm is the rev limiter on a stock machine with stock ECU/CDI. Same on RX-1.
Blown14psi
Thanks Guys
Yamaha did it right then. I have a supercharged mustang, and when it hits the limiter it cuts fuel but not the spark so it leans out big time if U spray with a wet kit.
