FoxFire227
- Nov 24, 2019
- Ottawa
- 2014 Viper LTX SE / MCX190
Hi all,
Can someone identify the part circled in this photo? It doesn't stay up and I noticed the pin was missing. I bought a new pin and hardware from Yamaha but have no clue how to install. I figured if i knew what it was called, i could google/youtube it.
Thank you!
Thank you!
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
If this is for your 2005 Rs venture it’s the outside spring.not much info on these online but the owners manual is available online,otherwise become a vip member&see if mr sled has a service manual he can send you electronically.sorry not much other info availHi all,
Thank you!
It's for two-up riding.
Stays up when doubling, down for solo.
https://www.cyclepartsnation.com/oemparts/a/yam/5003c1a2f8700212fc8417e4/track-suspension-1
Elton Buss
Go to Port Yamaha web site you can see it is #35&36 on the parts fiche. Spring holder I would imagine in the vertical it would work for two up riding, horizontal for one rider.
that looks like the torsion spring overload blocks on a venture. need to figure out them as i have a set to add to my apex xtx.
