Clay350
- Oct 29, 2010
- Minneapolis (just moved here)
- www.treetopsmedia.com
I know I could find this if I wasn't lazy and searched more. I'm about to put back in my new skid and track on phaser. When I took old track out I just left drive wheels in place and cut the track since it was toast anyway. What's the easiest way to get drive wheels out of the way to get my new track in?
Clay
Clay
Pull off all side plastics, remove battery and battery tray, take off parking brake and brake caliper. Remove brake disk and drain chain case oil,then take off chain case cover. Take off chain and lower sprocket. go to other side of machine and take off all bolts holding axel bearing to cast frame. (Rite under the secondary clutch) the drive axel will fall out now. Instal in reverse order.
3wheelerdude
- Jan 6, 2010
- Ottawa Ontario
- 2019 Voyageur 600
2019 ZR200
1991 Ovation 340
1986 XLV 540
Previous sleds: 1996 Vmax600, 2007 Phazer, 2016 Bearcat 3000
I also had to remove 3 bolts holding the bearing retainer on the chaincase side once the bottom gear was removed. That allowed easy re-assembly also.
I forgot about those? Thanx!
Clay350
- Oct 29, 2010
Thanks guys. Tearing it apart as I type this
