Hey everyone I need some help troubleshooting some of my problems. I have done extensive research on TY and the rest of the web but still can't figure out a fix to my problem. First of all I would like to share a little background. I upgraded this winter from my 1998 Vmax 700 to my dads 2006 Apex RTX. Although I knew my dad likes to ride his sleds hard, I figured for $4000 I couldn't beat the deal since it was December already. Well needless to say I have had to put in quite a bit of money already and am almost regretting buying the Apex.
I started out the year buying a set of tuner skis hoping this would be my only purchase of the year. Well unfortunately I quickly had to put a battery in her then my drive shaft bearing and speed sensor quickly went on the first ride. Next came the secondary shaft bearing and bushings for the steering. Well after I fixed all of this only five rides into the season I now have a noise coming from the skid area. I never noticed any noise until after I had the skid off to change the drive shaft bearing. When im riding at low speeds 5-25mph and going over any kind of bump (rollers or moguls) it almost sounds like the track is ratcheting. However, I have adjusted the track within specs, checked the wheels, and made sure the track wasn't rubbing on anything. No welds have snapped on the skid nor does anything look out of place. I am new to this sled though and don't have too much knowledge on what to be looking for so I could be missing something. For a clarification, I only hear the noise when going a low speeds. If I hammer down over bumps I dont hear the noise.
Lastly, my reverse has now stopped working. It engages into reverse then once it moves 1"-1' it slips out and grinds extremely bad. I don't want to do any damage to the gears or anything in the chain case. I have researched and found that it could be from the linkage. I adjusted the linkage to within specs and also tried adjusting a little out of spec to see if I could fix it. It first started two rides ago after I fixed the secondary shaft bearing. The first time it happened it just grinded a little bit but it never slipped. Now it wont even move before it slips. I thought maybe it could have been when I was replacing the secondary shaft bearing but I never went into the chain case and instead just removed the bearing right from behind the clutch. If anyone can share some advice on either of my problems I would really appreciate it.
I don't feel like calling my friend who is the mechanic at the local Yamaha dealer because quite frankly after having him replace my drive shaft bearing I realized how expensive it is to hire someone to do the work.
Sorry If I posted this in the wrong area. Feel free to move it
