jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
Never was an issue for me, and I'd do it again. That makes no sense anyway, as the pulley setup I was using means the sc was running at the lower end of rpm.
They were probably talking about an engine failure, not sc failure.
It was in the supercharger install setup and warranty is all I know.
Is a oil temp sensor a must for the supercharger, I assume no at low boost as well?I bought a Koso x2 but I can only monitor one
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
I have never used an oil temp gauge on a boosted sled, they just aren't fully loaded long enough to build up too much heat in the oil, unlike a truck pulling a trailer up a long grade...Some even have built-in coolant to oil coolers anyhow.
IMO there are more important gauges to take up gauge space like Water Temp, AFR, or Boost.
The limiter kicks in at 9200, which means I was usually just below. Wasn't something I was worried about or ever would be.
Detonation is time sensitive, so I don't want to under rev it either, but I found it had t be up here in order o be much faster than stock.
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
Is a oil temp sensor a must for the supercharger, I assume no at low boost as well?I bought a Koso x2 but I can only monitor one temp.
jgustman
- Feb 25, 2005
- Cottonwood, MN
- '10 Nytro RTX
- Cottonwood, MN
The Koso x2 should be called x3. It measures a/f, boost and water temp. Don’t really want to add oil temp if not needed. As far as running not much faster than stock at lower rpms, I assume you left gearing stock or do you mean acceleration also? I am going to be pissed if it isn’t much better than stock acceleration-wise.
I don't think so.Is a oil temp sensor a must for the supercharger, I assume no at low boost as well?I bought a Koso x2 but I can only monitor one temp.
Remember it is a low boost kit from Yamaha who are pretty conservative.
Gary chute
- Feb 3, 2020
- Grantsburg wi
- 2009 Yamaha nytro xtx mpi supercharger
Does anyone have the head gasket procedure and torque specs for 2009 Yamaha nitro I am in need of replacement ASAP
Attakapex1000
- Nov 30, 2018
- 2010 supercharged Nytro
Gary, so what are you doing with the supercharger removing it?Does anyone have the head gasket procedure and torque specs for 2009 Yamaha nitro I am in need of replacement ASAP
Gary chute
- Feb 3, 2020
- Grantsburg wi
Yes I removed it
Attakapex1000
- Nov 30, 2018
would you be interested in selling the 27 tooth pulley?
Gary chute
- Feb 3, 2020
- Grantsburg wi
The pulley got damaged when removing it from the charger so it’s no good sorry .
