Mtnviper
- Aug 19, 2003
- Burlington Wa.
- fourstrokesolutionsllc.com
Mine did the same thing last season. When I checked it out, I found blue bromofungiean (corrosion) down in the starter relay (solenoid) terminals.
On mine it looked like water had wicked its way down the terminals, and I suspect corroded the relay contacts inside.
I replaced the starter relay and applied some die-electric grease to the connectons just for good measure.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
ok well going to dealer tommoro so ill ppob get a relay and some new plugs CR10EK of course
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Id get the relays from like a napa
basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
talked to my dealer and they think i got a bad connection on a cylinoid
revster
- Aug 18, 2004
- La Salle MB
- 2009 Yamaha Nytro RTX SE
anyone know what the relay number is?
Mtnviper
- Aug 19, 2003
- Burlington Wa.
revster
- Aug 18, 2004
- La Salle MB
Mtnviper said:
Is that the Yamaha part number or the relay number?
Zakre
that is the yammie part number
zeke66
sj said:Id get the relays from like a napa
They sell them?
Mtnviper
- Aug 19, 2003
- Burlington Wa.
Yep, I call it a starter solenoid. It is refered to as a starter relay in the Yammie parts catalog.
The positive battery cable connects to it, and it has the two fuses mounted to the top of it.
It's easy to replace, I recommend dis-connecting the ground cable from the battery first. To prevent accidently shorting out your wrench, when removing the battery cable from the solenoid (relay).
Bill
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
Mtnviper said:I recommend dis-connecting the ground cable from the battery first. To prevent accidently shorting out your wrench, when removing the battery cable from the solenoid (relay).
Bill
Ahhhh, the old 12V arc welding warning.....
Good advice.basic700
- Mar 5, 2010
- Norwalk WI
2015 SRViper XTX LE
2009 Nytro XTX
Edited, first post
Doogs
Do yourself a favour and buy 2 relays. Even if you put dielectric grease it can still happen again. Especially if your sled frequently goes from a heated building to cold and back, or gets left in the rain.
