winderup
Can someone help me? I believe I have seen threads on a siezed secondary stock roller? I have just noticed two are spinning and one is not. Help please?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Have you removed the secondary from the jackshaft yet? If so than remove the three nuts holding the helix onto the sheeves,once apart look closer to see that the one you may have thought was not moving,was in fact froze,if itttttwas get a set of new rollers,either stock or aftermarket and unscrew the set scrrrw holding the pin,and take a small allen wrench and poke the pin out through the hole,and remove the roller off pin,and replace I new rollers,all three,and reassemble your good to go.Can someone help me? I believe I have seen threads on a siezed secondary stock roller? I have just noticed two are spinning and one is not. Help please?
winderup
I have not removed anything as yet, I just noticed one roller is not spinning. Thanks for replying.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
You are welcome bro,hope it all works out good,we finally got snow and groomers are out.I have not removed anything as yet, I just noticed one roller is not spinning. Thanks for replying.
- 10K
