Whent out today and drained my coolant and put the rear up with the drain screw out put in the anti-freeze until it came out the hole then put the screw back in. I used 2 1/2 L of anti-freeze and 1 1/2 of water. I went for a ride and the fan and temp light came on and the rear cooler was cold. Can anyone tell me whats going on?
grader
air lock. raise the front of sled( snowbank) remove rad cap and idle sled. air will bleed out and add coolant to tank to fill.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
How high does the sled have to be? Just hogher than the rear exchanger? I don't have the stock deal anymore. Running a u cooler. No bleed off...
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I take my forklift and raise the front about 2 to 3 feet. Works well.
