trdehmer
Friend has a 2019 SRX with 265HP BMP tune with their intake.
Looking for input to get the most HP to the ground for clutching!
Primary Spring
What weights are ideal? Dalton adjustables?
Is the secondary helix good?
What about recommended secondary spring?
Also, likely would re-gear to better gears/chain - what gearing is recommended for 1000' and 1/4 miles runs. Thinking we'd likely gear this thing down.
I know there are multiple ways to skin a cat, but hopefully there is some general consensus on a "clutch kit" that will work well!!
Thx!
Primary Spring
Thx!
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Use search above, lots and lots of clutching information.
kuvasz
my buddies and i have 4 new srx's. if running the 265 tune i'd suggest the adjustable weights from 70-76. i bought the dalton dtya1 and the weights without any slugs are too heavy (75g) for the max 16 tune. i can run 8900rpm with the weights empty with the max spool 17.
i tried the green primary and i went back to the stock spring. i left the secondary at 3+3 with stock spring.
i'd leave the stock 21/41 gears in it. when i went to the top 22 tooth and my 2 buddies with the same tunes had stock gearing there was no difference on the radar gun in 1/4 mile lake runs.
trdehmer
The Daltons are on the list.
I feel this thing could use different primary and secondary springs - blew a belt after 500 miles after some racing. So guessing the belts still slip in these, so I'd assume more spring pressure in the secondary would be ideal? Maybe different helix too?
Fleecer
- Jun 13, 2014
- 2019 SRX
Put Hurricane alignment bar on it and check clutch offset. My 19 SRX was off 2mm. Misalignment could contribute to the heat also.
PowderFalcon
Pinnin' it!
Put Hurricane alignment bar on it and check clutch offset. My 19 SRX was off 1mm. Misalignment could contribute to the heat also.
My ‘19 SRX was off 3.5mm!!
