pjabas
- Feb 11, 2013
- Montgomery ,MN
- 14 sr viper xtx se. 153" track turbo
So i bent my rails on my 14 xtx..
What cat model or models will work i would prefer go with 153 Length and just need some direction on what fits...
Thank you im advance
Mtnviper
Vendor
On the uncoupled rear skids, the difference in length between the 141", 153" and 162" rails is in the length behind the rear arm mounting point. They did change the rails ahead of that point through out the various years though.
As long as you stick with the same year (2014) rail, you should be fine.
pjabas
- Feb 11, 2013
- Montgomery ,MN
Ok but what model cat sled can i get 153s from..
I tried talking on the phone to the lady at sled junk yard. But wasn't any luck.. They don't have any yamaha parts...
Mtnviper
Vendor
The 153" rails would be from the M series mountain sleds such as the M8000.
suprfst
12 to 15 should bolt right into your 141 skid. 16 and up have longer front shock and higher mounting point for front arm where it goes onto rails. all years 141 to 162 use 3 pitch track so no driver change needed.
