New '07 Attak Won't Start-it's not the relay....too cold???
you need a block heater
I do not know what the part number but yamaha sells a heater that is installed in the lig cooling system and a battery heater we use this in alaska if not around plugins you could carry a small jumper unit like used for cars you can plug them in and charge them when around elec then plug your sled in a few hours ahead in the morning depends how cold it is in real bad times you could drain just the oil tank and heat it inside your cabin at night thats what bush flyers did in the old days up here in the bush yes sounds like a pain but will work in a bind kim
