darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
Here is the part number for the up- date kit for SideWinder 8MA-W002H-00-00
here what it comes with
90266-06001-00 outer weight rivet 3
8MA-17604-00-00 Secondary spring seat
90508-60012-00 Secondary spring
Fast
- Sep 25, 2018
What sidewinder is it for why was it updatedHere is the part number for the up- date kit for SideWinder 8MA-W002H-00-00
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
It's to update a 2017-2018 Sidewinder model to 2019 specs (tip rivet, secondary spring, helix).
chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
The $10 question is; What angle is the Helix?
The service manager told me that the secondary spring is the same as the Viper?
DIwarrior
- Oct 22, 2003
- Drummond Island MI
- 2021 SRX
2021 Sidewinder LTX GT
2020 Sidewinder LTX GT
2001 SRX
- Drummond Island, MI
- Nope
What is the advantage of this kit for those of us running a stock setup? Reliability, performance or both?
- Apr 17, 2003
- Menno, SD
- Menno, SD
Progressive reverse angle 35/39
The pink secondary spring that is in the update has been around since 2003 in the RX-1.
This shouldnt effect guys who already have aftermarket clutch compoments.
almond1000
- Jan 20, 2008
- North Fond du lac, Wi.
- 2017 sidewinder 2011 vector gt 2010 fx nytro 2009 vector gt
Im by no means a clutching guru, maybe someone else would know, but just out of curiosity, I'm running a tp kit with the 33/35 reverse angle helix and orange springs, would there be an advantage going to the 35/39 helix and taking some tip weight out of the hh's?
- Nov 29, 2009
- sabattus, maine
I wouldn’t, you’re reducing clamping force on the belt at both ends doing that.
upnumber6
- Jan 3, 2016
- Winnipeg
- 2007 apex rtx, 2011 apex se
Is that pink secondary spring not the same shitty one that was causing coil bind in a lot of sleds and some ppl on here were getting away from and going to a different one?
If so it don’t sound like much of an upgrade
upnumber6
- Jan 3, 2016
- Winnipeg
Bit the bullet and grabbed the kit today. Might get out tomorrow and try it out. See what the difference is
I was hoping a kit was coming that had better primary rollers.....ho hum.
Conedodger
- Mar 2, 2017
- Tulsa
- shopping, blew up my 07 MachZ1000
Can anyone comment how the pink spring compares to the TP orange? I bought the orange and installed over the summer, no run time yet. How do the SRX primary weights compare to the 2018 primary weights? Shape, weight, both?
Here you goCan anyone comment how the pink spring compares to the TP orange? I bought the orange and installed over the summer, no run time yet. How do the SRX primary weights compare to the 2018 primary weights? Shape, weight, both?
http://www.daltonindustries.com/product_detail.php?product_id=293
