rtx moose
- Jul 31, 2014
- WATERTOWN,MN
so anyone get a new drive axle and measured the diameter?is the new one bigger and in tolerance?
Turboflash
- Mar 18, 2019
- Southern MN
Nothing has changed to my knowledge. I just repaired 2 TCats w new shafts and new bearings. On new shaft the bearing journal is about .0015" smaller than a new bearing (a GOOD bearing not Cat bearing although they should measure the same).
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Sad Cat and Yam will not fix this, and with new model yr coming too.
How have the guys who added the BOP wedge been making out? Is the Wedge a true longterm fix that has no issues?
Dan
Dan
You'd think they could ad one or two thousandths easy enough to make it a slightly snugger interference fit.Sad Cat and Yam will not fix this, and with new model yr coming too.
Dan
I fail to see how that would be a difficult change on the assembly line process.
Turboflash
- Mar 18, 2019
- Southern MN
IF it was a press fit, one could no longer just slip the caliper housing onto the end of the shaft, slide it up to the tunnel, and then install the seal plate on the inside with the 3 bolts. One would have to press the housing onto the bearing journal, AND importantly get it in the exact right place so the bearing isn't side-loaded one way or the other. Then how could you install the shaft? It's not rocket-science but would require changes in assy process and special tools.
I'll let you know next week and post pics as I just had my track shaft spray welded (the brake side bearing failed and damaged the track shaft) and I had them size the bearing journals so I will have somewhere between .0005" - .001" press fit on both sides of shaft. I will be building a special tool to install bearings on both sides.
And I did have the BOP wedge on my sled but that doesn't help if the bearing itself fails. Bearing spun in caliper housing AND shaft (even w wedge in it). Bearing locked up.
Same. Waited 3 months for this one. Made them open up a new bearing sloppy as heck. Bought it anyway will have to fix.
Turboflash
- Mar 18, 2019
- Southern MN
Yup. New bearing (6009 is 45 mm ID = 1.77165". So on yours, you have .003" clearance which makes for a pretty sloppy fit of bearing to shaft. Terrible!!
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
You can't measure that with any caliper.you need a micrometer or pressure mic for these kind of tolerances..I do this for a living and these measurements need to be down to the tenths to fit correctly .ooooSame. Waited 3 months for this one. Made them open up a new bearing sloppy as heck. Bought it anyway will have to fix.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I drilled 4 dimples in the shaft and used retaining compound last summer!! I'll know in a few weeks if it held up or not when I take it apart for annual maintenance.
Also have a customer dropping off his sled monday for a track change and maintaining who did the same so I'll have 2 sleds to compare
Turboflash
- Mar 18, 2019
- Southern MN
I think KnappAttack did this too but it didn't work. Hope yours turned out better.
My caliper-side bearing failed (locked up) so I had my track shaft spray-welded and sized up the journals so I will have a press fit both sides with new bearings. I'm still gonna use green sleeve retainer Loctite on caliper side (not on chain case side as shaft usually doesn't spin in that bearing).
I'm assembling it this weekend so I'll post some pics of what I'm doing with it.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Keep us posted. I bet many are watching this.
I have the BOP saver, but wont know until I pull it apart in a month or two how it helped.
Cant believe Yamaha and Cat just keep plodding along. But then again look how long it took to address the tri hub.
Too bad there isn't a snap ring against the inner race on both caliper and chain case side bearing. Gotta believe that would help.
Failing that, a lock nut of some kind to bind the inner race to the shaft would be a great idea. Total re work of the design, I know but this is ridiculous.
MS
MS
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Maybe yamaha/cat did a change this season??? We won't know until the 2021 part # list comes out
BTP
- Jan 5, 2018
- Michigan
- 2018 Thundercat, 2019 Thundercat
Whats the bearing number for a higher quality one? What brand?
Bull they are that bad!You can't measure that with any caliper.you need a micrometer or pressure mic for these kind of tolerances..I do this for a living and these measurements need to be down to the tenths to fit correctly .oooo
I also slid a new bearing on. It’s so sloppy no reason to bother getting mic out of tool chest. This is 2020 zr 8000 shaft part #. Maybe Yamaha got some good ones but you all best check before taking home.
