x2thez
- Mar 29, 2005
- Buffalo, NY
- 2014 Yamaha Viper LTX
2009 Yamaha Vector LTX
1987 Yamaha Bravo
So because my sled was at the dealer already for the chaincase leak I asked them to see if there were an updates. They told me no, the latest one is from 2016. Because my dealer is about 1 hour away each direction I decided I would give Yamaha Corporate a try to see what they have to say. I heard back from them today and from what customer relations was told for the US, the most recent update is the one from 2016.... So guess its 2 starts for me this winter.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
It's a long paper trail for Yamaha to bring the flash from "development" to the doors of the dealership. The "development" part is done on the new flash, now it must go through a significant paper trail to get to the end user.
MtCooler got his Pussy cat flashed and he is happy so far. 1 try start smooth idle and felt it turned over faster.
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
I had my XF 7000 flashed this afternoon. I brought it home, it was a couple of degrees below freezing. I turned the key and held it a little longer than I expected it would take, but it started. Idle was around 1800 rpm for a little bit, then it settled in around 1500. Idle sounds good. Then I left it for an hour and then went back and tried it again. The next time it took two tries! Shoot! Oh well, at least the idle sounds good and it does turn over fairly fast. That's all I can really report because it just isn't that cold out yet. Here's hoping that this is the fix...
cobrajet ltx dx
Can any dealers on this sight comment on the 19 viper or cat 7000 starting characteristics?
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
I wish I could but the only sled we got this year was a Sidewinder.
sk-rx1
Dont forget Yamaha choose not to use the "new" bodywork on the '19 Viper. No reason to think they would do a reflash just because Cat did.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I was told by a Canadian friend that a Yamaha dealer near Hamilton Ontario was doing the flash on the Viper and charging $100. Can anyone confirm this?
Snowfun
- Dec 7, 2014
- Waterdown, Ontario
- 2022 SRViper L-TX GT
What problems are they trying to fix with this latest update? Where might one find out about this?
Thanks for your 'help'.
Not sure about Canada but here in USA a dealer would get in trouble for that. Even if not. What a shitty thing to do.I was told by a Canadian friend that a Yamaha dealer near Hamilton Ontario was doing the flash on the Viper and charging $100. Can anyone confirm this?
Last flash left us with 2 try starts,big backfire and random stalling. Assume attempt is being made to fix that.What problems are they trying to fix with this latest update? Where might one find out about this?
Snowfun
- Dec 7, 2014
I wonder if the sled was not bought at that dealership and was brought in for other work?I was told by a Canadian friend that a Yamaha dealer near Hamilton Ontario was doing the flash on the Viper and charging $100. Can anyone confirm this?
Yamasledder
- Mar 7, 2010
- Brandon, Manitoba, Canada
- 2020 Viper LTX SE
That shouldn't matter. I had mine reflashed last year and didn't buy the sled in the same city and I'm not the original owner.I wonder if the sled was not bought at that dealership and was brought in for other work?
Clyder6R
- Dec 24, 2015
- Atlantic Canada
- 2015 Yamaha Viper MTX 153 McXpress 190 kit
How will this reflash effect my sled with the MCxpress 190 kit on it??
It should be fine BUT I have a AFR and right at cruising speed light throttle I noticed my map was lean after the last flash.How will this reflash effect my sled with the MCxpress 190 kit on it??
