monker
alaskanbowtie
NICE !!! I knew it would be a great piece!
I wanted one of these on my sled but Aaron was thinking they wouldn't be ready to sell until the end of Oct. My sled ships like the 20th so i'd have to be able to buy one by the tenth of Oct. , if you think this is an option let me know, (if you sell them) so I can have outlaw change the exhaust plans. How long before we have Dyno numbers and price ?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Pricing is looking like $529 currently. The unit is full stainless steel. There is going to be a slight change to the design of the end cap, but otherwise that is a production unit. Dyno numbers will be available either the week of October 16 or October 23. Depends on which week I make the trek to the dyno!
tmk50
Let us know what you find out - any chance of a group buy?
pro116
excell
That look's pretty big is there going to be clearance when the suspension is fully compressed?I'm very interested though.
alaskanbowtie
YES
When I talked with Aaron he said it will clearance everything fine, all been checked. Also said you'll be able to get rid of everythig related to the other exhaust and the heavy cast aluminum bracket as well yeilding over 20 lb weight savings.
- Apr 17, 2003
- Menno, SD
- Menno, SD
No clearance issues as it does not sit any lower than the stock canister. The exhaust is a complete bolt in and go kit, no modifications to the sled at all.
vectorboy
Seat ?
Which seat can one use with this exhaust ? Boss etc ?
www.mountainmod.com for a seat that will work....
- Apr 17, 2003
- Menno, SD
- Menno, SD
Mountain Mod & Boss should both have seats.
vectorboy
Boss/Mountain Mod ?
I know they both make a front turbo seat from Boss and Mount Mod but are these the same seats that would work with this exhaust ? Is there enough clearance between the pipe and seat ? Just curious, i really want one of these Excells. I would rather have a Boss over the Mount Mod just because of the seat foam. Ideas
I'm going to run this exhaust with a mountain mod seat. The mountain mod seat foam issues are resolved with a custom batch to there specs....so I wouldnt let that hamper the decision....plus you get a huge trunk...a base that bolts on and no SNAPS to pick the ice outta when the seat pops off.
vectorboy
When you say the seat foam issue has been resolved ? I really like the MM seat, do you have any pics of the front mount turbo seat from MM ?
Frostbite
I'd like plastic close out panels for each side of the seat and the rear of the seat shipped with the pipe.
Heck, even better than that would be to have Aaron build and ship a plastic storage box that fills the area and looks top notch.
I assume this pipe will work just fine with ECP filters?
Frosty
Frosty
