Angelo
- Sep 5, 2020
- Saskatchewan
- 2016 Yamaha Viper 153 w/ MPI Turbo
Greetings. I am very new to this site. While I am not new to snowmobiling I did make the jump from a 2013 Polaris 800 Switchback Assault to a 2016 Yamaha Viper MTX 153 with the MPI turbo.
I’m going through this machine after I bought it and have some questions. Please help - any feedback will be appreciated!
1. There appears to be a small melt on the side panel where the exhaust is. When I remove the panel there appears to be this heat blanket - it looks like it has seen better days. Can these be replaced and if so from where? Are there other alternatives to this instead of the blanket?
2. There isn’t an accessory for the my helmet - what’s the easiest way to bring one in? I do see there is an accessory inlet but nothing for a helmet windshield
3. The MPI turbo cold air intake that sticks out the side has a rip in the sock. Where can I guy get a replacement sock for this?
Welcome!
Make sure the can is intact and not leaking. Can get some heat tape at auto store to better protect the panel. If it’s the one that just hangs down many of use used a aluminum can cut and stapled to it to repair it.
Easiest source for powering heated shield is a adapter that just goes into the power socket or Rockmiester here sells a nice one that has usb outputs also.
That sock not sure but lookup K&N online. They have a bunch of sizes and styles. Outerwears also.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Cat sells a cord for your helmet that plus into an accessory plug that is located on the wiring harness near the top of the chain case. You can then rout he helmet end up near the base of the handle bars.
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
* Yamaha Deluxe Heated Shield Outlet -- SMA-8LR10-00-00
quentin lemay
- Feb 14, 2020
- ALBERTA
- 2015 Yamaha viper mix 162 mpi turbo
Ordered a replacement sock for my mpi kit thru CR racing. I got the 6 inch one.
Fits very well. And cheap.
Angelo
- Sep 5, 2020
- Saskatchewan
Where did you order it from?Ordered a replacement sock for my mpi kit thru CR racing. I got the 6 inch one.
quentin lemay
- Feb 14, 2020
- ALBERTA
Website is CRracingCanada.com
Angelo
- Sep 5, 2020
- Saskatchewan
Ah - that’s a great side for us canucks. Thanks!!!!
