horkn
Re: Rush
IIRC, Yamaha started using glue to put frames together on streetbikes like 5 years ago.
It actually is a sound construction method applied by some exotic sports cars as mentioned previously.
Also, the rush was not "rushed" into production. This idea came out at least a year ago, and I am sure the chassis has been tested quite a bit.
apltx08 said:horkn said:Snowaddict said:Another funny tidbit said was that the Rush has no welds. Supposedly is all glued together. Glue doesn't melt until a significantly high temp (I forget the exact degee #.) You've got to be kidding me!
Does your friend sniff a lot of glue?
This is to funny...![]()
could you imagine yourself jumping a few feet of the ground then once you land it all falls APART!!! having to pick up all the peices and bringing them to your dealer in a cardboard BOX!!!
