Started at zero out. Went for a 15mile ride to a clubhouse, then no start leaving. Cranked, heard the fuel pump running and had dash light up but no start. The kill switch was in the proper position. I repetitively turned on the key and kill switch, then started. What relay froze?
Last time I had no start without the dash lights, it was the ISC, but replaced ISC and fuel with sealed ones. This seams to be a different one that caused this issue since I had dash lights. Thoughts.
Justa change all 4 of them in the fuse box and its done. It also could have had corrosion on the Kill Switch contact.Started at zero out. Went for a 15mile ride to a clubhouse, then no start leaving. Cranked, heard the fuel pump running and had dash light up but no start. The kill switch was in the proper position. I repetitively turned on the key and kill switch, then started. What relay froze?
