It is normal to lose some pressure as there is no engine position where all the valves are closed at the same time. So there will be leakage through the ring gaps on whatever cylinder doesn't have the valves closed.I did a pressure test on both sleds and found that if I pressure up to 15 lbs and stop, I lose 1 lb every 2 seconds, so I lose 5 lbs in 10 seconds. That doesn't seem like a lot to me ... am I wrong? Is losing 5 lbs in 10 seconds excessive? Seems like any loss is made up at the wastegate and so boost would stay the same.
Bill
However if both sleds lose leakdown at the same rate, it doesn't explain the speed difference.
Bill Hooper
- Jul 20, 2016
- Michigan
- 2012 Polaris IQ Turbo
2009 Polaris IQ Turbo 2up
2000 Polaris XCR 800
The faster sled is running at 8300 rpm at 112mph. I am informed that the ideal RPM is 8800 RPM, leaving room for additional top speed. Given it has Thunder Products clutch kit, it should be pulling 8800 rpm and it isn't. This is why I think there is a problem.but is the faster sled running at the ideal RPM and the slower is over reving? loading it heaver would make it work hard to make speed if it has the HP to pull it.
Bill
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Stock 8 JP belts! Asking because the xs825 aftermarket belt will bring your revs down!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Have you checked clutch temps between the 2 sleds?
Belt slippage could be your issue on the slower machine.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
If faster sled is turning less rpm than the slower sled turning more rpm either your gearing or drivers are different or you have clutch issues IMHO .
Or speedo is off
Or speedo is off
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Do a clutch assembly swap sled to sled. Primaries, then secondaries. See if the problem follows either clutch.
Should hold 20 lbs of pressure and have a very slow bleed. Same exhaust in both sleds? Guys use the stock shields over a non stock exhaust. Sled hitting 112 @ 8200 RPM is way too heavy and needs weight taken out of the primary. Other sled isn't getting fuel or not making boost.
- 24K
