dremmick
Are these available anywhere now that pioneer performance is closed?
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
91 Phazer II (gotta have a classic / kids bomber :) )
The dealer is still there last I knew and I bought the bushings from them for the discounted or clearance price. Give it a shot
nydiver
- Apr 30, 2015
- Syracuse, NY
- 09 Nytro XTX
09 Nytro RTX
7164966000
Tod
call travis at barn of parts or ulmer--
dremmick
barn of parts does not have any for an 08 nytro. I would like to use Nylatron since I heard they are way easier to install.
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Are you talking about the oil-light bushings being hard to install? Nothing a rubber mallet and a 2 x 4 wont fix. I put a set from Ulmer in my Phazer into fresh powder coated A-arms and don't remember them being to difficult? I will be installing another set in an 08' Nytro I just picked up this summer. G.B.
herndonp
Love the nylatrons, but not sure you will find any.
Pete
Pete
dremmick
I am definitely having a hard time finding them.Love the nylatrons, but not sure you will find any.
Pete
Tod
yes I guess I meant the oil light---that is what I put in the front of my nitro---and did stock oem in the rear skid
BADSLED
- May 13, 2004
- Syracuse, NY
- 2012 Nytro MC Xpress 270
2011 Apex SE
2021 Sidewinder LTX SE - SOLD
Any one know who sells Nytro replacement Nylotron bushings?
The copper/iron "oilite" everyone seems to be selling is not holding up as well as the old style replacement true copper "oilite" bushings.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
@BADSLED you should be having no issues with anyones oilite bushings if they are made out of the correct material. I believe maybe some of the Yamaha/MPI are made out of the cheaper material (and maybe some of the other vendors as well, I do not know for sure though) as the correct material is very expensive and will last, but you have to charge more for them. Give me a call or order off our website, we have the toughest material available in "oilite" form.
- Apr 17, 2003
- Menno, SD
- Menno, SD
There are two different grades of "oilite" material.
Low grade oilite
Low grade oilite
- Tensile Strength, psi 14,000
- Yield Strength, psi 11,000
- Tensile Strength, psi 22,000
- Yield Strength, psi 22,000
Mileage Quest
Thank you Allen for my 2011+ Apex oilite kit... I was unable to locate a kit for my sled until I called Allen 3 days ago... After a short chat he helped locate another loose steering bushing down by the power steering box... My order arrived in less then 48 hours and I may even get my sled back together for one last ride this weekend...
Thank you again Allen for amazing customer service at Ulmer racing...
Any chance for a paid internship Allen???
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
I just did the same thing, check out my Front End + thread, not hard at all to install. Same, I did fresh powder coated A-Arms, I used a c-clamp and pressed them in and then you do have to be "solid" with a few final taps into position with a solid spacer (I used a steel 1"x5" disc my Father had) so you don't ding up the oil-lite bushings.Are you talking about the oil-light bushings being hard to install? Nothing a rubber mallet and a 2 x 4 wont fix. I put a set from Ulmer in my Phazer into fresh powder coated A-arms and don't remember them being to difficult? I will be installing another set in an 08' Nytro I just picked up this summer. G.B.
Snowman871
- Feb 9, 2010
- Woodville, WI
- 2024 Polaris Assault 850
I installed Ulmer's oilite bushings when I did the front end on my 09'. I saw pictures of a neat little DIY tool somewhere on the web. Basically threaded rod with washers and nuts to press the bushing in, super cheap to make and made the install a breeze.
