NytroFx
Any advice?
NytroFx
Just bought sled. Don’t know. First 4 stroke
NytroFx
Just bought sled and it’s my first 4 stroke so I don’t know.what skis do you have?
wolfe9904
- Dec 29, 2013
sounds like you have alot of ski pressure. The nytro is very nose heavy espically when you let off the throttle. I would look at you center shock spring and see how far it is cranked up. if its pretty loose you want to tighten it up. does the rear of the sled feel really loose in the snow
NytroFx
Trying to figure this site out. But yes it’s very loosesounds like you have alot of ski pressure. The nytro is very nose heavy espically when you let off the throttle. I would look at you center shock spring and see how far it is cranked up. if its pretty loose you want to tighten it up. does the rear of the sled feel really loose in the snow
wolfe9904
- Dec 29, 2013
ok so you want to tighten the center shock spring up. that will take ski pressure off and give you more track bite. There are two nuts on there. loosen the locking nut on the bottom then tighten the spring nut to put more tension on the spring
NytroFx
Cool thanks.ok so you want to tighten the center shock spring up. that will take ski pressure off and give you more track bite. There are two nuts on there. loosen the locking nut on the bottom then tighten the spring nut to put more tension on the spring
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Any single keel ski with single runners will dart in the right conditions.
Best handling improvment is snowtracker skags. Easier steering, precise handling and no darting.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Tuners are a good solution and cost effective for this sled.
The nitro likes tuners and the twin keel does not dart
Ms
Ms
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Post a picture of the skis and we can identify what skis are on your sled. G.B.Just bought sled. Don’t know. First 4 stroke
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
Any of the dooly style carbides will largely take care the darting. Bergstrom triple point and snow trackers will as well. Make sure the front and is good shape, that the skis and A arms don't rattle around, and the alignment is correct. I had tuner skis, and went to Curves. The tuners don't float well in deeper snow, and push a lot in loose snow.
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
toe out
Gone Blue
- Oct 11, 2006
- Howell, Michigan
On my new to me 08', the first time I rode it I was running stock skis with 6" Stud Boy Dooly's, shimmed a 1/4" and a 1/2" total toe out. Very little to no darting on a hard packed trail. Swapped those skis out with a pair of Pilot 6.9's with 6" Shaper bars down the center and 4" round bar carbides on the outer edge. Running ZX modified rubbers mounted backwards. Darting was totally dependent on snow conditions. Super hard packed crusty snow, I had some darting. A little fresh snow on the trail, no darting. Its my opinion, that no matter what the sled set up is, darting will very with snow and trail conditions. At least on a Nytro? G.B.
Bristowfxnytro
Have a set of slydog 8” powderhounds with a set of 6” ats carbides and it darts like a mofo. Might put on some doolys next year but I don’t know how I feel spending $94 a carbide...
