sxvipersman
- Mar 19, 2006
- Dover Centre,ON Canada
- 2008 FX Nytro RTX Anniversary Edition
1979 Enticer 340
2009 FX Nytro XTX
Installed a 1.6 cobra 128" I have lost 500 rpm. Which way do I need to go with gearing to recover rpm. And do I need to change the chain.
2008 nytro rtx.
2008 nytro rtx.
need to put in one tooth larger lower if possible to make a taller ratio.
sxvipersman
- Mar 19, 2006
1979 Enticer 340
2009 FX Nytro XTX
So go to a 22 top great to be able to pull More rpm.?
you actually would want to go 20 on top to gear it down.
stock is 21/39 = 1.85 to 1 gear ratio
stock mtx is 20/40 = 2 to 1 gear ratio
what i am suggesting is go to a 21/40 = 1.90 gear ratio or you can go with a 20/39 = 1.95 to 1 gear ratio to get your rpms back in line with where they should be. i suggest the 21/40 as you are not down by much.
i cannot tell you if the 21/40 will work with the stock 68l chain but the 20/39 will for sure.
sxvipersman
- Mar 19, 2006
1979 Enticer 340
2009 FX Nytro XTX
Thanks gear on order.you actually would want to go 20 on top to gear it down.
