boardmandan
- Jan 15, 2013
- Waterford, MI
- ZR9000, Nytro XTX - Gone, Viper RTX-DX - Gone
Finally got the supercharger installed and from the MPI info, it says that the blue LED on the right will be on if controller is adding fuel above 1 psi boost. At idle this led will be off, on solid, or flashing. Boost gauge reads -2.5 while this is happening. Do you know if this is normal operation?
Sounds about normal.. Will you get a green when on the gas slightly? What gems setting are you starting with?
boardmandan
- Jan 15, 2013
- Waterford, MI
The first led is green at idle along with the intermittent blue. Sounds like you dont get the green while idling.Sounds about normal.. Will you get a green when on the gas slightly? What gems setting are you starting with?
I checked what the controller came set to and i have 4 settings and they're all set at 4. That almost corresponds to the values listed for version 3.1.
Any recommendations? I will get some trail time on it this weekend and can try some tweaking. Afr gauge seems to be working well.
Do you have 4 modes or 5 modes? There are some out there with both.The first led is green at idle along with the intermittent blue. Sounds like you dont get the green while idling.
boardmandan
- Jan 15, 2013
- Waterford, MI
Just 4 modes.Do you have 4 modes or 5 modes? There are some out there with both.
Sent from my SCH-I545 using Tapatalk
Just 4 modes.
Mode 1 = 1.5
Mode 2=3.5
Mode 3= 3.5
Mode 4= 3.5
boardmandan
- Jan 15, 2013
- Waterford, MI
Will give it a try this weekend, thanks!Mode 1 = 1.5
Mode 2=3.5
Mode 3= 3.5
Mode 4= 3.5
