snowmaaan
- Sep 7, 2005
- Fairmont, MN
- Yamaha Sidewinder, Viper XTX Turbo, Apex SE, Vmax 4, SRX 700
- Farimont MN
I am at sea level and running Ulmer Clutching. It runs hard at 6lbs of boost with an excel header and Ultra Q exhaust. However, I have not tried any other clutch setups...wondering if anyone has tried any HeelClicker or Dalton setups. If so, what is working??
Thanks and Merry Christmas!
Snowmaan
Snowmaan
TurboTime
snowmaaan said:I am at sea level and running Ulmer Clutching. It runs hard at 6lbs of boost with an excel header and Ultra Q exhaust. However, I have not tried any other clutch setups...wondering if anyone has tried any HeelClicker or Dalton setups. If so, what is working??
Snowmaan
Ulmer uses super tips in his clutch kits, they work great. Also, where you add weight to the tips will drive performance through low,mid and top end.. Why fix what is not broke? If anything you may want to change your helix and or springs, depending on what you are looking for...
snowmaaan
- Sep 7, 2005
- Fairmont, MN
- Farimont MN
I hear ya. It works fine...however I have used Heelclicker setups in the past that pull really hard up top and provide low end accel/torque that is hard to find in any other profiles.
ctp1528
schimtd brothers motorsports
Call Chris he did my clutch for my low elevation and that thing flys . I have run a lot of kits and then man is the best not saying the others aren'tbut he really is great .
