Ski Whiz
working on a nytro that was involved in a collision with a car on clutch side. Clutch shaft was bent about 1/16th" (visual assessment) so i decided to check stub shaft. It has approx .010" run out at the tip of the shaft. I assume this is too much and will cause vibration issues etc??? Or are these stub shafts more forgiving than are traditional crankshaft arrangement? Opinions??
Keith1962
- Mar 26, 2015
- Camillus, NY
- 2009 Nytro XTX,OFT Relocator, Excell exhaust, Curve Skis, Excell wheels, Dupont Slides. Star Suspension. Hygear Billet rear shock and spring spacer. Air Box Mod. Clutch mods, Polished tunnel. Custom GPS mount. BOP Skid Plate. RSI handwarmers.
It will shake. The shaft should be replaced.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Call Travis at barn of parts , he may have a wrecked sled that shaft or whole assembly can be purchased.
It’s easy to change with a shop press and a the right plates.
Ms
Ms
