yamatyb9
I am picking up an '09 nytro fx 121" on tuesday Evewrything has been well taken care of and recent oil change, exhaust donuts, jack shaft bearings and front bushing recently done. It has an ice ripper track on it i believe and was just wondering everyones thoughts on studding it, and if so how many evryone runs?? Also is there anything else to check out right away when i get it home? First nytro ive owned finally.
Thanks!!
Thanks!!
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Check speedo bearing clutch side by footwell. Should be replaced if it hasnt been changed. Also fuel pump relay to updated red version. Fix the problem before you get stranded lol. http://m.ebay.ca/itm/OEM-Yamaha-Sno...Relay-8GN-81950-00-00-Red-Relay-/261927400011 your local dealer Should have stock.
I run an ice attack 1.22. Love it for trails. Good bye studs.
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Oh and HOLD ON. nytro motor rocks
full tilt viper
- Dec 25, 2009
- Nytro MPI Stage 1
You can stud the ice ripper. Running 234 studs @ 1375 on a 144 . Only 1 pull through after 3 seasons.
mcamzr
Congrats, the ice ripper should be just fine and no risk of throwing a stud through the exchanger. I say ride it before you spend any money on it, but if you must spend money on it and want to tinker I say relocate the steering first.
yamatyb9
thanks for the replies.. And go figure the sled im trading ('02 viper) decided to get a gas leak out of the carb i assume anyways, today i noticed.. Gotta get that fixed before tuesday and hopefully get my nytro i been waiting for!
Bahr05
- Dec 18, 2010
- Medford, WI
- '09 Nytro XTX
How much they giving you on trade for your viper?
yamatyb9
im not trading it in, found a guy on CL that wanted to trade me the '09 nytro and little cash for my '02 viper and '03 rx1. Was a good deal for me i believe anyways .
