Kristian Kristiansen
Can anyone listen from the sound of the video what the problem can be ? It's really slow on low rpm
Sounds like its not making any boost..
On the boost gauge i have 0.7 in boost pressureSounds like its not making any boost..
that’s all the boost?? No wonder it’s slow. Check for boost leaks in plumbing.
0.7 bar , i will check plumbing from throttlebodies. I know it's not exhaust leak because i changed exhaust donuts yesterday.that’s all the boost?? No wonder it’s slow. Check for boost leaks in plumbing.
would that be 10 PSI? If thats the case then I would think the clutching may be to heavy, was this a new build or it pulled the clutching before?
Yes 10 psi. Last week i upgrade fuel pump to 270 hp, before with the other pump and injector the throttle respons was much better. So i think it's a leak someplacewould that be 10 PSI? If thats the case then I would think the clutching may be to heavy, was this a new build or it pulled the clutching before?
This is from the top of the intercooler, this i think it's not correct? It's just a blended hose
You should be taping into the line that goes to the blow off.
kviper
Sounds like it's stumbling when you open the throttle. To rich? You put in the pump and injectors and then the problem came up? Do you have an AFR gauge? Maybe to much injector and or to much fuel pressure for 10lb boost.
Yes the problem came after i put in New pump and injectors. But also boost pressure went down
I dont have afr gauge only boost pressureYes the problem came after i put in New pump and injectors. But also boost pressure went down
kviper
It has to be related to the changes you made or a boost leak from something you had apart. What turbo kit is it? I would contact them for setup. You might just need a fuel pressure adjustment? I assume you have a boost indexing fuel pressure regulator? Also you should have a AFR gauge otherwise you don't know where you're at.
Yesterday i had the sled inside a warm garage so today it did run good with much better response on low rpm. But after 1 hour i started stumble again
It's mcxpress turbo kit
