kennyspec
- Sep 30, 2009
- stonewall, manitoba
- nytro
i Picked up a 16 viper with a blown engine. Going to swap in a engine from my Nytro.
First problem is the viper engine seems to run two oil pressure sensors and the nytro only runs one. The viper has a 2 bolt bracket that is tapped into the case of the engine. There is no way to mount the bracket to the Nytro case. Hoping to get a T adapter fitting made up. The Nytro oil pressure sensor is bpt. The other sensor is a different thread
Does anyone know if the 3 wire oil press sensor is just for the gauge? Or will it throw a code without it? Is there any other position on the engine i could mount it to?
SwedeViper
- Nov 7, 2016
- Norrbotten
- Sweden
- Viper M-TX 2016 MCX 270
Just curious... what happened to the original motor in the 2016 Viper? Turbo?
kennyspec
- Sep 30, 2009
- nytro
It was the poor rod engine. Rod through block. Not my doing i bought it this way.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Turbo?It was the poor rod engine. Rod through block. Not my doing i bought it this way.
I have a spare Viper motor. Heck I have the whole chassis. It could be yours??? Located in Indiana I think it is still under 1000 miles
kennyspec
- Sep 30, 2009
- nytro
How much for the motor?
kennyspec
- Sep 30, 2009
- nytro
Yes sled had a turbo
2k with or without chassis.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Did you buy it with turbo, was it removed prior to your purchase and are you planing to keep it n/a or is turbo going back on new motor.Yes sled had a turbo
allyammies
Look io grizztracks viper glider build. Should help you out.
kennyspec
- Sep 30, 2009
- nytro
I have looked Into it. He used Nytro electronics. I will be using electronics from viper for now.
