WINDER1987
yes i did i tried giving it a little throttle a couple times then tried giving it a lot of throttle lol with no change I am going to get some CR10EK plugs from auto zone tomorrow and hopefully that fixes it.
Make sure that the gas tank vent line is not pinched, pull the gas cap and then give it a try.
WINDER1987
never thought of that good idea .
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
yea, and dont start it repeatedly and shut it off, that creates a lot of moisture in the tank and the motor..remember you exhaust runs right under the tank, heats up the fuel a bit then it cools, and boom, water in your tank..
what town are you in rday?? I see your in NY
WINDER1987
I am in Lisbon NY 2 1/2 hours north of Syracuse. Very sweet sled Btw rigidone
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
Thanks Rday, She runs pretty good..
I travel to Lisbon for work, Evans farm Repair is one of my accounts I sell to..
WINDER1987
Really that is literally 2 miles from me lol.
I bet she runs alot better than mine does right now lol
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
Yep, I'll shoot you a PM next time I'm up that way..
WINDER1987
Ok sounds good bring the sled lol
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
I would think about changing the plugs. They could be due depending on how many times you started it and shut it off right away. I like to change mine every 1000 miles to keep my performance top notch.
WINDER1987
What is a good safe method if I need to start it in the garage from time to time to guarantee no plug fouling?
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
I just dont start mine until im going riding..last time my sled was started was April. But if you have to start it, let it fully warm up, not just until the red light goes off..and if you can get the #*$&@ end up in the air so you can give it some juice would probably help too..In the past when I needed to start mine because I did something, the sled was definitely doing a lap or two around the yard. to get everything up to temp and moisture out of the motor..
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
Change Plugs. They are fouled..... Run till she gets good an warm before shuttn down.
WINDER1987
I bought this stand I'll run it for a good hard couple. Mins for now on if I do anything to it.
RIGIDONE
- Jan 5, 2009
- SYRACUSE, NY
- Pro S Switchback
ride it around the yard, it's way more fun..lol...but yea, that should work..
you dont take the fuel tank off to change the plugs do you??
