Aaron maheu
- Sep 23, 2014
- Maine
- 2013 nytro xtx
This morning I woke up it was -20. I decided to let the sun come up and go for a ride to check the trails for broken trees in the way. Left my sled outside not in the garage. Went out to start it and all it wanted to do is turn over over over and over like it wasn't getting fire. So I decided to take a heat gun and warm up the throttle body for a few min. I don't know what the hell I did but it started up ran flawless all day. Does anyone no what I did to fix the issue? It was very cold so it has to deal with spark or fuel or electrical. Thanks for the reply
Can you hear the fuel pump when you turn the key to the on position?
Aaron maheu
- Sep 23, 2014
- Maine
- 2013 nytro xtx
No I can't is it one of the relays?
Replace the fuel pump relay in the nose of the sled with the solid state version or bring yours in the house and thaw it out. Call Kevin at Port Washington Yamaha they have them in stock.
Aaron maheu
- Sep 23, 2014
- Maine
- 2013 nytro xtx
Thanks so much for the info. It's still under warranty. Yamaha should carry them correct.
I'm sure Yamaha carries them but does your dealer is the real question.
Quince
- Jan 25, 2015
- 07 apex attak
This happened to me this weekend with my apex just had to feel witch relay was faulting and I replaced mine with the red solid state. Works great was -35 yesterday and fired up.Thanks so much for the info. It's still under warranty. Yamaha should carry them correct.
- 6K
