09nytro
Is there anyway to bypass the 02 and not by a PC or a remap ....His choice. Low speed and idle was easy to tune myself. No risk either way just don't want o2 sensor messing with any of my maps since it runs so nice without it. That stock sensor is not wideband anyway does very little except cause light and $ when it burns out.
Yes. I guess since no one else is going to make a kit I will. All it is is a resistor and jumper wire.Is there anyway to bypass the 02 and not by a PC or a remap ....
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
Isn't the pc5 optimizer a resistor a "dummy plug" to fool ecu??Yes. I guess since no one else is going to make a kit I will. All it is is a resistor and jumper wire.
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
I'd buy a kit from you, I'd like to get a PC5 someday too.
Yes.Isn't the pc5 optimizer a resistor a "dummy plug" to fool ecu??
I will make this easy for some enterprising person. Here is the dummy plug(Optimizer) from my PCV. I will try to source the parts to duplicate this but guy could just cut the wires on your stock O2 sensor to use the plug. Would just have to buy a resistor.
Resistor value
Resistor value
jpr-ltx-dx 2015
- Sep 21, 2014
- sr viper ltx dx
your wasting time,the ecu did never took care of the o2 sensor since day one on viper.as it was told before,it only trow code whwen it fail.
the next reflash will not take care of o2 sensor just like 2017 guys.
I know that. That is the reason for bypass. No code. Maybe the new flash will also allow O2 sensor removal WITHOUT A CODE? Also getting rid of it removes any chance that it is doing something. All the talk of it not doing anything is not official.your wasting time,the ecu did never took care of the o2 sensor since day one on viper.as it was told before,it only trow code whwen it fail.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Resistor value
I am by no means an electrical expert, just trying to help out with guys looking to bypass the sensor.
328 ohm is kind of an oddball number. I think your seeing some tolerance fluctuations. Thats most likely a 330 ohm resistor. Which is pretty common to find..
Not trying to correct your post, just trying to clarify some for anyone that might be looking to do this.
Right. I did get same reading 3 times. Every time so confident in the reading. Good meter too. I will get some resistors 330 ohm and give it a try this weekend. Thank you.I am by no means an electrical expert, just trying to help out with guys looking to bypass the sensor.
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Resistors values are nominal. A carbon fiber resistor come with 5, 10 and 20 percent tolerances while metal film typically have 1 percent tolerance. A 330 ohm resistor with 5 percent tolerance could have a value of 330 +- 16.5 ohms. I doubt the bypass resistor needs to be precise but if it does a 332 ohm 1% would have a 335 max value and 329 min value which keeps it close to the measured 328. If you have a large selection of resistors available as I do you can combine them in series or parallel to get more values but that's probably not necessary for this application.
I did this mod on a Yamaha Stryker that I had a few years back and found it wasn't worth the effort. A correctly programed ECU is the proper fix.
Thanks grizz. Many have had o2 heater circuit fail and throw code. This would be a good long term solutionResistors values are nominal. A carbon fiber resistor come with 5, 10 and 20 percent tolerances while metal film typically have 1 percent tolerance. A 330 ohm resistor with 5 percent tolerance could have a value of 330 +- 16.5 ohms. I doubt the bypass resistor needs to be precise but if it does a 332 ohm 1% would have a 335 max value and 329 min value which keeps it close to the measured 328. If you have a large selection of resistors available as I do you can combine them in series or parallel to get more values but that's probably not necessary for this application.
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
Grizz you lost me
Doesn't the +or - value mean that it can measure 'anywhere' within that +or - percentage
So by your example you say 1% of 330 is +335 or -329. In my math 1% of 330 = 3.3
So wouldn't the resistor read anywhere from -326.7 to +333.3
What am i missing?
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
A standard 1% resistor only comes with a nominal value of 332 ohms not 330 as found with greater tolerances. I guess I should have explained that better. The possible values for a 332 ohm resistor which is closest to the the desired 328 ohms would be 332 +- (332 x .01) = 335.3 to 328.6
http://www.daycounter.com/Calculators/Standard-Resistor-Value-Calculator.phtml
Mtnviper
Vendor
I did this mod on a Yamaha Stryker that I had a few years back and found it wasn't worth the effort. **A correctly programed ECU is the proper fix.**
I agree with that statement 100%
